suntravel wrote: ↑Wed May 04, 2022 11:55 am
I assume you have 16x5mm ball screws
Yes, they are 1605 ball screws
25,4/5=5,08revs per inch if your steppers are 1:1 on the screws.
Steppers are attached directly to the ball screws, so 1:1 ratio. With the stepper driver set at 3200, a 1 inch command gives 1 full rotation.
I am unclear about what the 25,4/5=5,08 means. Is this 25.4 mm (1 inch) divided by 5 mm (pitch) = 5.08 revs per inch?
I don´t think they have more power than for 1000 rpm : 1000/5.08 = 196,8 in/min max rate
Not sure what you mean. Where did the 1000 rpm come from?
I used the formula in the thread. DM542T drivers show 200kHz in the specs, so I calculated it as:
3200 steps per rev times 5.10204 turns per inch = 16,326.530 steps per inch linear travel **Note** the 5.10204 turns per inch is coming from the downloadable spreadsheet in the thread. Since I am using a pen to make tick marks, I can accept that 5.08 is probably what I need. The 5.10 is likely from measurement error. But it doesn't explain why my Y-axis is not anywhere near that value.
At 200k steps per second...
200000 times 60 seconds = 12,000,000 steps per minute
12,000,000 divided by 16,326.530 = 735 inches per minute (max)
The y-axis inches per minute max is being skewed because it appears to be moving more than what is expected for identical conditions and settings.
You must know the pitch of your screws, than it is easy.
I do, they're 1605 ball screws. The pitch is 5 mm
Finetunning is an other thing, but needs a high resolution dial indicator.
I have a dial indicator that I can use with this.
