Rigid tapping Setup
Rigid tapping Setup
Maybe useful for someone...
My Setup for rigid tapping
Servo Driver 0.1s deceleration and acceleration time
Parameters in Acorn
0.25s acceleration for z-axis in the Wizard
P36 - 1
P37 - 0.1
P68 - 800
P69 - 0.2 (lower produced some overshoot)
P82 - 45
P143 - 1
P240 - 500 (for a metric setup)
P241 - 10
works ok for tapping in the 800-2000rpm range with my cheap Closed Loop Steppers
Direction change in the hole (especially from 2000-0 rpm) could be faster for my taste but found no way to speed this up further
Re: Rigid tapping Setup
Uwe,
Hello. nice work as usual! thanks for sharing.
would be great to pan the camera over to the Acorn CNC12 screen during these demos to prove that its an Acorn that is running the show:-))
cnckeith wrote: Wed Jan 26, 2022 3:59 pm Uwe,
If it would be Linux CNC I have had to talk 15min how difficult rigid tapping was to set up, an then looking at the slow tapping I would fall asleep :D
But ok next video with Acorn screen and the complete single line of programming in Intercon :lol:
thanks!! looking forward to it. ;)
rruizvial
CNC Control System Serial Number: 7804738481A4 0130191589.
Post by rruizvial »
Is like a siemens controller.
cnckeith wrote: Wed Jan 26, 2022 4:49 pm thanks!! looking forward to it. ;)
Here you go.
Made a Video of the part I had to make today with complete workflow....
love the rigid tapping! snappy!
nice work on this cool little machine.
thanks for posting this great video.
jpmsteadi
CNC Control System Serial Number: E415F6F1121A-1204204111
Post by jpmsteadi »
That looks great! Nicely done!
Which encoder did you use? I’ve ordered one of the cheap omron knockoffs, but I’m a bit concerned that it won’t work with my 7k spindle.
jpmsteadi wrote: Sun Jan 30, 2022 10:07 am That looks great! Nicely done!
400line SFEncoder, because Omron an the knockoffs will only work to 6000rpm with 1000 lines, 3000rpm with 2000 lines
jpmsteadi
Post by jpmsteadi »
makes perfect send. Do you have a model number?
