G98 Why is it necessary?
In watching Marty's video about calibrating the overall turns ration and backlash he stresses to use a G98 before moving the Z axis. Why is/are he/you using the G98? I looked it up but couldn't figure out why it was necessary. I am CNC challenged! I have never been a CNC operator and never played one on TV!
Re: G98 Why is it necessary?
G98 specifies a feed rate in units per minute rather than in units per revolution of the spindle
OK, I am trying to calibrate a metric mill so that is not necessary for me to use. Thank you.
- CNC Control System Serial Number: 0035FF8FEB5F-0708203490
It allows you to move your axis without the spindle turning when you don't have an encoder hooked up to the spindle for RPM.
G98 for lathe is different from G98 for a mill
Though I should have said "G98 specifies a feed rate in units per minute rather than in units per revolution of the spindle"
I have corrected it.
Got it. Danke!
A subprogram call is M98, not G98.
G98 on a mill specifies that, after a canned drilling/boring/tapping cycle, Z should return to the initial height it was at before the cycle.
But as has already been established, when doing test moves for axis calibration, backlash measurement, etc. you need G98 on a lathe control. You do not need any equivalent command on a mill control. Not even if you have a spindle encoder on your mill.
Thx. Wasn't paying attention at 6am
