Mini Lathe Encoder System Fault
Re: Mini Lathe Encoder System Fault
If that is the case them M4 = CCW = NEGATIVE NUMBERS.
mujenpwr
CNC Control System Serial Number: 4519
Post by mujenpwr »
So I need to change the value to negative in the wizard for the encoder value based on a CCW M4 as shown below? The encoder is belt driven and the encoder is spinning in same rotation direction as spindle.
The arrow drawn on the photo is CLOCKWISE rotation. It is commanded with M3 and the encoder counts should be positive in this direction.
mujenpwr
Post by mujenpwr »
Thanks Tom got it.
mujenpwr wrote: Tue Jan 18, 2022 10:09 pm Thanks Tom got it.
