Wirerless Remote note working <install Pro License>
Posted: Sun Jan 16, 2022 1:19 pm
I built a gang tool lathe some years back and it is dedicated to 4 jobs. The tooling setup never leaves the table.
I am sure that the updates are 4 or 5 versions old if not older. It works well for my needs so I leave it alone.
I powered up my system and turned on the remote and the screen is blank all but the battery level and signal strength indicator.
There is a little square that blinks when I rotate the MPG wheel, that is all I get.
I replaced the battery, I moved the antenna to other USB ports and restarted the system mutable times. Is it dead?
