I have a 2.5mm pitch ballscrew and I need to set up the overall turns ratio in the wizard. How do I set up a units equation to convert a metric screw pitch to one in inches?
I have a 20 tooth gear on my motor belted to a 50 tooth gear on my ballscrew. That gives me a 2.5:1 gear ratio (50/20). So my initial overall turn ratio should be 2.5*ballscrew pitch.... I did some incorrect assumptions and made the ballscrew pitch just a simple mm to inch conversion (2.5mm = 0.0984252in) but that gave me a pully reduction ratio of 0.25 and some change which is extremely low. My mill axis doesn't even noticeably move with that input. I know there is the measurement method to get the overall turns ratio but I'm still on page 53 of the setup manual getting my initial numbers roughed out.
metric thread pitch to SAE question
Re: metric thread pitch to SAE question
25.4 / 2.5 = 10.16 * 2.5 = 25.4
(mm per inch) / (metric pitch) = (ballscrew turns per inch) * (screw pulley) / (motor pulley) = (turns per inch)
2.5 seems awful fine for a ballscrew. Are you sure?
Thank you! Now that I see it I feel a little dumb for not initially knowing how to do the conversion lol. I guess I'm not 100% positive it's a 2.5mm pitch ballscrew, the companies out of business and I got that info from a very knowlegble ex-employee. Now that you have me questioning it I'll measure a rough estimate tomorrow to see if its close.
turn the screw one revolution and measure how far the axis moves.
what type of machine is this on?
common milling machine metric pitches are 5 and 10
router 20 for XY and 5 for Z
related reading.
https://centroidcncforum.com/viewtopic.php?f=63&t=1801
and please always post a fresh report.zip when requesting support.
related reading.
