ENCODER INSTALLATION: INDEX PULSE PROBLEM
Re: ENCODER INSTALLATION: INDEX PULSE PROBLEM
The FAR better solution would have been to purchase the line-driver version of the encoder they are using and dispense with the added expense of designing and building a converter.
Hi Stefano,BioAgeLtd wrote: ↑Mon Jan 03, 2022 5:50 amDear Marty,martyscncgarage wrote: ↑Sun Jan 02, 2022 1:54 pm Glad you found the electrical issue with the index pulse, but I think you are going to have issues because that encoder is NOT belted TO the spindle at 1:1 with a timing belt. Gears have lash....
thank you for your suggestion, If I will notice this problem then I will update the encoder fixing following your setup
Best Regards Stefano
if you remount the encoder with a belt, do not put sideloads on the encoder, the pulley should have its own bearings and the encoder mountet with a coupling to the pulleyshaft.
Regards
