Hi Keith,
That is good news. Thank you, looking forward to it.
Bill
Error message <fixed>
- CNC Control System Serial Number: E062346A1C67-0716214939
Re: Error message
you are welcome thanks for posting.. currently this is the only known bug (and a intermittent one at that) in v4.80... pretty happy about that!
Re: Error message
So glad you guys found and fixed this. Looking forward to 4.81. It was driving me mad on my plasma table.
Re: Error message
link to v4.81 BETA mill, lathe, router, plasma CNC12 installer with file management bug fixed, please test out..
if no issues arise from this build it will become v4.82 official release.
Its always best to do a fresh install and configure the system by hand using the Wizard. make screen shots of existing running install and a fresh report.zip. then use screen shots to reenter data and settings in new version Wizard. for plasma, Be sure to set plasma THC back to ON in the profile manager.
https://www.filemail.com/d/ykobkrjnchewpth
1.) Mill, Lathe, Router, Plasma: Fixed a rare intermittent file management bug that appears in some systems but not others. This solves the ”(OPEN) Error saving offset library” and ”(OPEN) Error saving tool library” issue.
2.) Plasma: Added Plasma oscilloscope plot button in Utility menu in CNC12 for opening the plot app inside of CNC12. Note the Centroid “Plot” program captures Actual Voltage, Position, Velocity for plasma machine performance analysis.
3.) Plasma: Restart mode improvements. Restart now supports M101 and Modified Feedrate by %
4.) Plasma: Plasma Intercon additions and improvements
- Profile Feedrate Override Percentage added to events
- dxf/svg events now have cut direction
- Canned cycles and kerf offset values are now modal
- Clicking/Double clicking event will save currently edited event
- Improved dxf/svg import
- Color Picker dialog loads with hex code and color selected
- Error catching for circular and rectangle frames
- Subprograms update more consistently
- F8 – Graph added to main screen
- F8 – Graph reworked
Re: Error message
Installed 4.81, so far so good. We'll see how it goes.
Thank you
Bill
Thank you
Bill
Re: Error message
I’ll install it on my plasma Monday as that’s where I’ve seen the file management bug. I also had the restart issue on my plasma but I was emailed a small workaround file from Centroid that has worked well. I have A LOT of 1/4” steel to cut in the coming weeks.
Re: Error message
plasma restart in v4.81 now supports M102 and %feedrate values.ShawnM wrote: ↑Sat Oct 29, 2022 9:40 pm I’ll install it on my plasma Monday as that’s where I’ve seen the file management bug. I also had the restart issue on my plasma but I was emailed a small workaround file from Centroid that has worked well. I have A LOT of 1/4” steel to cut in the coming weeks.
Re: Error message
Thanks Keith, looking forward to trying it out.
Re: Error message
Yes, all good here as well.
