Delta VFD-VE TB229
- CNC Control System Serial Number: 7804739E42DF-0925192491
Delta VFD-VE TB229
Is there a wiring diagram that supports TB229 for Acorn? I think I have everything wired correctly, except I'm getting a whopping 5-7rpm from the spindle motor. The VFD-VE is equipped with a EMV-PG02, which I can't find documentation for on Delta's website, but it seems that everything from the PG01 is still the same.
Re: Delta VFD-VE TB229
all acorn schematics are here,
https://www.centroidcnc.com/centroid_di ... browse.php#
search "acorn vfd"
creating wiring diagrams for the 1000's of VFD's out there would be daunting. most use the Acorn to Generic VFD schematic and cross reference the connections to the particular one they are using, you'll most likely need the manual for the VFD you have to do this.
search "acorn vfd"
Yeah, I got it working. Thanks for the link. Is this search page new? works great.
yep! thanks.... its a old page that we updated to work better, it directly pulls the schematics from our database on our server so all the latest schematics will be at your finger tips...so as soon as we make an improvement or add a new schematic it will automatically show up on this page so always refer back to this page when looking for the latest hookup information.
