The procedures you described are exactly my procedures actually.ShawnM wrote: ↑Sun Dec 12, 2021 5:55 pm You have to home the machine at every start up BEFORE you start anything. Either "simple home" or "home to switches", there's no way around this. You can shut down the machine at any time without parking or moving or rehoming the gantry. Just shut down at anytime anywhere. Next time you power it up you'll have to home that machine again.
It sounds like you don't have your homing setup properly or you don't fully understand how it works. I'm confused by your comment "One thing I noticed is that I have to move the CNC like 0.010 or 0.100” and then set home when I turn everything on, if I hit cycle start the CNC does not home it errors out." What do you mean it errors out? Do you have a screen shot?
A standard start up procedure would be-
- turn on the pc so it starts to boot up
- turn on the machine control aka your Acorn (doesn't matter the order, Acorn then pc if you like)
- after the pc boots and you have a heartbeat on the Acorn launch CNC12
- software opens and the message window reads "9033 Reset Initiated, press reset to clear"
- press the reset button and the message window now reads "4032 reset cleared"
- at this time you must press cycle start to home the machine, it'll either simple home to it's current position or home to the switches but either way it'll home and the DRO will then read all zeros.
Now the machine is homed and ready for you to tell it what to do. This procedure is the exact same at every start up. As stated earlier, you can close CNC12 and power down the machine with the gantry in any position. You dont have to park it or move it or do anything special.
What is your procedure? What errors are you getting?
By the way, I can’t duplicate the error I was getting
Shawn, I sent you a private message too.
