Axis is affected by VFD
Hello everyone, we have a cnc acorn and XSY-AT1 VFD
We have a problem with axis when we connect the analog output of acorn to analog input of VFD
The axis automatically moving without command
What will be the solution?
Thank you in advance
Re: Axis is affected by VFD
search "VFD" and "Noise"
here is how.
here is how.
Keith gave you a suggestion to search.
Please follow and provide the information requested in this post:
Post a picture of your control cabinet as well.
ALWAYS Post a Fresh Report when asking for assistance. F7 Utility, F7 Create Report
It contains your machine's parameters and logs. Have you taken a look at your error log? F7 Utility, F9 Logs, F1 Errors
Thank you everyone,
Now I have a view for the problem
I will post the Logs when I'm back to work.
Inexpensive Chinese VFD's can be problematic.
VFD cable sized and connected appropriately between the VFD and the motor is suggested.
automationdirect.com sells such cable. You need to know your motor current draw.
TLDR: Use shielded cable and terminate it properly
Thank you everyone, We solved the VFD noise problem by grounding the shielded cable to the body of machine.
Unfortunately, we encounter a new problem with the axis. When moving the z axis the axis travel exceeded by 0.01 mm every millimeter it travels, we check it by using dial indicator.
Any idea how to solve this?
Thank you in advance.
- report_6433DB139597-0818215098_2021-12-14_15-38-45.zip
- (687.33 KiB) Downloaded 58 times
See this post on calibrating the axis turns ratio: https://centroidcncforum.com/viewtopic.php?f=63&t=1801
Are you following the Acorn Installation guide? If you follow the steps you should be golden.
install manual.
is found here with all acorn documentation.
