Setup profiles for Router - Laser - Lathe
edcross
Post by edcross »
When i ran Mach 3 /4 , i had 3 machines set up , i would just start the profile in the Mach loader that i wanted to run . Same machine with different attachments ( spindle - laser - rotary driven lathe ) . How can i setup acorn to do this ??
Ed
Re: Setup profiles for Router - Laser - Lathe
Assuming all the limit switches and other connections remain the same, you can either keep a report for each setup and just restore rhe one you want to use, or you can keep separate directories for each setup and just rename the ones you want to use to CNCM and INTERCON.
