How can I create work offsets or work stations?
Gary Campbell
Re: How can I create work offsets or work stations?
Post by Gary Campbell »
Actually I should have said press the "GOTO XY 0" button on the VCP
guerra_cues
CNC Control System Serial Number: 0035FF98CA2D-0813215079
Post by guerra_cues »
Gary Campbell wrote: Mon Dec 06, 2021 10:07 am Actually I should have said press the "GOTO XY 0" button on the VCP
Hi Gary,
Where is that go to button on the VCP? I don’t have it or maybe I need to create one?
Tony Maninha
www.facebook.com/guerracues
Using Centroid Acorn Router "Pro" CNC12
guerra_cues
:D
tblough wrote: Mon Dec 06, 2021 9:13 am "GOTO WCS" means select the WCS you want by hitting alt-1 for WCS #1, alt-2 for WCS #2, etc., and then MDI "X0Y0" and hit cycle start.
Neither of these methods (nor MDI) will work until the machine is homed.
Amazing! And it works too :lol:
I just added the Z0 too - X0Y0Z0
Thanks everyone for the help on this one.
Tony Maninha
Sword
Post by Sword »
Yep, no need for a cycle start or MDI. Just Alt 1,2,3, etc. and "GOTO XY 0" button. You can also set up a button on the MPG to use do the same with a simple macro.
M25
G0 X0Y0
Scott
guerra_cues
Sword wrote: Mon Dec 06, 2021 11:56 am Yep, no need for a cycle start or MDI. Just Alt 1,2,3, etc. and "GOTO XY 0" button. You can also set up a button on the MPG to use do the same with a simple macro.
M25
G0 X0Y0
Scott,
I do not see the GOTO button you guys are talking about. See the screenshot attached.
Thanks!
Tony Maninha
Sword
Post by Sword »
Yeah, you're using the mill version. The router version has it, but you can just add it yourself. The button may already be in your resources/vcp/buttons folder
Scott
guerra_cues
Sword wrote: Mon Dec 06, 2021 12:03 pm Yeah, you're using the mill version. The router version has it, but you can just add it yourself. The button may already be in your resources/vcp/buttons folder
I guess the million dollar question is should I be using the router version instead for the type of CNC I have? If I need to use the router version how do I change to that version without loosing all my settings?
If that’s ok to stick to this version how do I add the button then?
Tony Maninha
Sword
Post by Sword »
You can just use "mill" and edit the VCP as needed. They're the same under the hood.
A little searching of the "sticky" Acorn forum threads yields....
https://centroidcncforum.com/viewtopic.php?f=61&t=4685
Scott
guerra_cues
Sword wrote: Mon Dec 06, 2021 12:27 pm You can just use "mill" and edit the VCP as needed. They're the same under the hood.
Thanks Scott!
Tony Maninha
