Unable to setup homing <answered>
guerra_cues
CNC Control System Serial Number: 0035FF98CA2D-0813215079
Re: Unable to setup homing
Post by guerra_cues »
tblough wrote: Wed Dec 08, 2021 2:14 pm F = FEEDRATE. nnn = Number
See also: http://www.cncsnw.com/4thHowTo.htm
Got it. Thanks Tom!
Tony Maninha
www.facebook.com/guerracues
Using Centroid Acorn Router "Pro" CNC12
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
guerra_cues wrote: Wed Dec 08, 2021 3:24 am Howdy!
So It is time to update everyone that helped and unfortunately still have a few issues going on:
The good news!
The limit switches were fixed (had 2 bad switches) and I was able to home the CNC successfully! Yeah!!!! :D
Still having some issues after being able to Home the CNC:
  • I am unable to Home the CNC with the A axis enabled (F6) - it homes the axis Z, Y and X still says that the machine needs to be homed. If I disable (F6) the A axis the CNC homes and is ready to go to work. What can I do to Home the CNC and still use the A axis?
  • Homing X is running at 15ipm, is there a way to change that velocity?
  • When I was able to use the rotary, if I issued a command in MDI like A120, it's accurate but super sloooooow, where can I change that jog speed? And what is a faster speed recommended?
At the end of the day the good news is the machine works very well but need to get the A axis situation fixed.
Thanks for all the input and help guys!
In the pic with the homing sequence - You have the 4th Axis A, set to Zero (0). Make it 4 and that axis will then home with the rest, last. Obviously it will need a homing switch.
Because your Slow Jog speed, Fast Jog speed, and Max Rate for the A axis are all in degrees/minute, you will probably want numbers significantly higher than 360, at least for the Fast Jog and Max Rate.
Try setting your Fast Jog speed to 1800 degrees/minute, and your Max Rate to 3600 degrees/minute.
guerra_cues
CNCMaryland wrote: Wed Dec 08, 2021 2:39 pm
The good news!
I don’t have a home switch on the A axis, I don’t need one. Is there a way to by pass that?
Tony Maninha
Create your HOME file, then go in and edit the .hom file and comment out the line with the A axis.
Then tell the wizard NOT to overwrite the Home file in the future.
guerra_cues
martyscncgarage wrote: Thu Dec 09, 2021 12:11 pm Create your HOME file, then go in and edit the .hom file and comment out the line with the A axis.
Hello Marty,
I followed cnckeith suggestion on editing the cncm.hom file (use Notepad ++) comment out the M code that seek the home switch and left the M26 /A alone :) Isn't that what you are referring to? However I didn't get a prompt to overwrite the Home file.
Here is the other thread:
https://centroidcncforum.com/viewtopic. ... 077#p57077
I did not meant to confuse anyone but I thought that this question deserved it's own thread.
report_0035FF98CA2D-0813215079_2021-12-09_10-57-12.zip
(635.25 KiB) Downloaded 58 times
Tony Maninha
Re: Unable to setup homing <answered>
Tony, in the wizard on the "homing and travel" page in the first section at the top left, you can make a choice about your cncm.hom file. The second radio button down says "I will create my own home program, do not overwrite cncm.hom". Make sure that radio button is selected and write those settings to the cnc control. This way when you modify the cncm.hom file it will stay that way. If you don't select this option the software will overwrite the cncm.hom file at startup and undo any of your changes that you just made. So check this box first and write the settings to the cnc control, green button at bottom of the page, and then go out and edit the cncm.hom file to suit your needs.
guerra_cues wrote: Thu Dec 09, 2021 1:43 pm
Hello Marty,
Correct
