Initial setup questions...
guerra_cues
CNC Control System Serial Number: 0035FF98CA2D-0813215079
Post by guerra_cues »
Hello,
I have 4 Clearpath SD motors and got them configured with MSP, but now I am lost...
I have read the manual and still don't get it on how to do basic things...
- How do I configure the A axis ratio? Should be 6:1
I was able to enable the A axis and do have the F6 command available to turn it on or off... When I go MDI the A axis is way off....
- I have loaded the configuration of the ClearPath SD and I have set in the wizard the CP motors to 1600 per the instructions as well on the MSP from Teknic.
I am looking for direction here because I am completely lost to get the CNC move the correct amount of distance and rotation. Feeling frustrated to say the least and I do have the Pro license.
Tony Maninha
www.facebook.com/guerracues
Using Centroid Acorn Router "Pro" CNC12
Gary Campbell
Re: Rookie questions...
Post by Gary Campbell »
Turns /deg = 6/360 = .016667
guerra_cues
Re: Initial setup questions...
Hi Gary,
I got all axis moving correctly now thanks to you my friend!
I do have limit switches on the CNC and if someone would be kind enough to point me on the documentation on to setup Home and the different offsets I can have I would appreciate it. I will read through the manual to see if I can find the information as well.
Tony Maninha
