Build advise please
Posted: Wed Dec 01, 2021 9:25 pm
I have three cnc devices (In varies stages of build);
G0704 mill
HY6040 router
7x10 lathe
Bought an Acorn, and am trying to decide how to best use what I have.
My first thought was to put everything in one box and switch the DB25 lines to the KL-8070D, KL-5056E, and M542T Drivers depending on whether I want mill, router or lathe.
___________________________________________________________________________________________________________
But
Currently, I am thinking to just have the Acorn in one enclosure with a DB25 cable out and then each CNC device would have another enclosure with the drivers and power supply, accepting a DB25 input.
Advantage of separate Driver enclosures is that the different devices can/do have different power supply values, ie 36v and 48v
Also I have a Pokeys57cnc controller and RMHV2.1, which I might also be use with these separate driver enclosures.
This second idea of separate Controller and Driver enclosures would require at least a DB25 cable between the two enclosures.
Feedback please...
G0704 mill
HY6040 router
7x10 lathe
But
Feedback please...
