z axis moves when spindle turned on
Re: z axis moves when spindle turned on
Not exactly the same scenario but before I added shielded wiring to control my VFD the spindle rpms fluctuated. I run my mill using a RPC and the converter made noises sympathetic to the fluctuating rpm. A simple fix but not something obvious.
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
Thanks for all the help everyone.
First I'll respond where I can:
@drdennis thanks for sharing the video, I'll definitely watch it....and probably see if I can coax my buddy who's an electrical engineer to come out and help me once I've fixed a few of the issues others have pointed out that I know aren't done correctly.
From what you guys have said overall I think I need to take a step back. yesterday I reattached the original spindle control box ground because I had a hunch that grounding that would also ground some of the shielding on the router. It helped, but the z axis moves on spindle startup, spindle shutdown and the z home kept changing while it was running a program.
For now, I'm going to take a breath and slow down a little bit. I was really hoping to make a few christmas gifts on it but I need to let go of that and take good care of this machine that I was unbelievably lucky to get at a price I could afford.
I'll monitor this thread and answer any questions but I'm going to take a step back, go back to my original build thread and start by documenting my build clearly. Then I'm going to buy good, shielded wire and rewire everything.
Yes they are, but like Marty said, they have been working fine for me. I don't have any trouble at all until I turn on the spindle.Aren't these the same drives as are having issues here? viewtopic.php?f=60&t=6477
I don't have any trouble with them moving on their own when I start cnc12. I don't know what they revision they are, but I only bought them about a month ago.Hi, I am having issues with my g214's moving on there own when I start cnc12. Have you had this problem? What revision version are your drives? Thanks
It's just 13-gauge romex, solid core, not shielded. There's a really good chance that's the problem. It could also be because I bought a cheap chinese VFD, I've heard they cause EMI headaches.Do you have a closeup of the yellow wire going into and out of the VFD? IS it shielded? Specs?
What is the make and model of your router motor and VFD? Pictures of their labels?
automationdirect.com sells VFD cable
Some cheap VFD's are absolutely horrible.
