VCP image problem
Posted: Sun Nov 28, 2021 7:20 pm
by Emzy cnc
Hallo
I love how i can modify buttons and move them anywhere and manual helps very much .
I have just one problem with my image ive drew. Problem is same as in trubleshooting page of manual , where VCP wont show up because of svg image.
Some buttons i did modify ( change colour and move feature around ) but soonest i draw new button , it wont work for me ...
what is wrong with this button ?
Ive uploaded button to google drive if somebody wants to take a look ...
Re: VCP image problem
Posted: Mon Nov 29, 2021 1:49 pm
link is missing
Posted: Mon Nov 29, 2021 9:04 pm
by WVDualsport
cnckeith wrote: Mon Nov 29, 2021 1:49 pmlink is missing
Click on his image. It opens the google drive .svg. You can then download it yourself, etc.
Posted: Mon Nov 29, 2021 9:06 pm
by WVDualsport
Emzy cnc wrote: Sun Nov 28, 2021 7:20 pm Hallo
Seems like it should work just fine. 100x100. I opened it in Inkscape to check it out.
Posted: Mon Nov 29, 2021 11:25 pm
by ShawnM
A couple of points.....
- the button folder name (inside the buttons folder), image name (svg file) and xml file all have to be EXACTLY the same name.
- is the image name spelled correctly in the skin xml file?
- when you saved the image did you convert it to outlines? (I use Adobe Illustrator and have to "save as outlines" in order for it to show up
What program are you using to create the button? (not that it should matter)
Let us know if any of this helped.
Posted: Tue Nov 30, 2021 2:11 pm
ahhh! thanks...
ok i opened the .svg and the first thing i noticed is that there are a million layers full of elements that are not being used. ok maybe not a million but a bunch of them. delete all the ones you don't need to eliminate problems that they are causing.
Posted: Tue Nov 30, 2021 2:24 pm
i edited the layers and joined some elements and here it is displaying on my plasma VCP.
Posted: Tue Nov 30, 2021 3:10 pm
here is the fixed image
Posted: Fri Dec 03, 2021 6:50 am
by Emzy cnc
Thank you guys, yes spelling is correct, as i did just copy and paste to be sure.
Could you please make some screen video of deleting those element and exporting image ? So i wont bother you with future images ?
