Si non samedi dernier j'ai fait les taraudages M10 et M6 qui fixe l'ensemble de ma structure
Posted: Tue Dec 07, 2021 12:41 am
ok, i'll guess....new it was probably around .125 mm?
looks like a single nut screw designed for a high speed application, not for precision.
you could measure it or find a model number and try to look it up.
by Filardo
If not last Saturday I made the M10 and M6 threads which fixes the whole of my structure
Posted: Tue Dec 07, 2021 12:53 am
by Filardo
Je ne l'ai pas encore reçu tous ce que je sais elle était montée sur une panneateuse salvagnini [
Posted: Tue Dec 07, 2021 12:54 am
by Filardo
I have not yet received all that I know she was mounted on a salvagnini panneateuse
Posted: Tue Dec 07, 2021 3:10 am
exactly. these screw are a good fit for that application. <not high precision>
what is your goal/purpose with the machine you are building?
Posted: Tue Dec 07, 2021 3:31 am
by Filardo
A little amateur violin making and a few precision pieces I haven't really defined all of this yet
Un peu de lutherie amateur et quelques pièces de précision je n'ai pas vraiment encore défini tout ça
Posted: Wed Dec 08, 2021 1:06 am
by Filardo
Je pense gardé cette vis a billes pour axe y
Comme ça elle sera accessible pour pouvoir la changer par la suite si ça ne va pas
I think I kept this ball screw for y axis
That way it will be accessible so that you can change it later if it does not go well
Posted: Thu Dec 09, 2021 1:21 am
by Filardo
Ball screw received heavy cleaning with wd40 then a little spray polishing paste on the lathe
PAs reference on the screw but it is from what I see the model tsl page 129 of the pdf
Vis a billes reçu gros nettoyage au wd40 puis un petit coup de pâte à polir en bombe sur le tour
PAs de référence sur la vis mais il s'agit d'après ce que je vois du modèle tsl page 129 du pdf
