Page 1 of 20
routeur cnc acorn auto construction
Posted: Sat Nov 20, 2021 5:41 am
by Filardo
voici le début de mon futur routeur
Posted: Tue Nov 23, 2021 3:35 pm
Hello! thanks for posting, looks like a great project. I'm going to move this thread into main Acorn Forum. that way you can keep posting your progress and if you have any questions we will answer them and help you out.
notes: moved this thread from success stories to main acorn support forum.
Posted: Mon Nov 29, 2021 3:09 am
by Filardo
Small day on Saturday where I finished the bases of my acorn cnc router
Petite journée de samedi où j'ai fini les embases de mon routeur cnc acorn
Posted: Mon Nov 29, 2021 3:16 am
by Filardo
Vue sous le routeur il me reste à fraiser la plaque qui va lier Le portique
Posted: Tue Nov 30, 2021 10:49 am
Nice!
Posted: Tue Nov 30, 2021 11:23 pm
by Filardo
Merci si tu as des conseils à me donner il faut m'en faire part
Posted: Wed Dec 01, 2021 4:03 am
by Filardo
Hello if anyone knows this brand of ball screw to know if it is weak it is a suton 3210 screw
Bonjour si quelqu'un connait cette marque de vis a billes pour savoir si elle est faible il s'agit d'une vis suton 3210
Posted: Wed Dec 01, 2021 9:17 am
by tblough
Based on the ratio of screw diameter to ball diameter, it is not a heavy duty screw. Based on the pitch, this would work for a router or plasma cutter. It is not suitable for a precision machine tool.
Posted: Wed Dec 01, 2021 3:45 pm
From Tom's post translated to French:
Basé sur le rapport du diamètre de la vis au diamètre de la bille, il ne s'agit pas d'une vis à usage intensif. Sur la base du pas, cela fonctionnerait pour un routeur ou un découpeur plasma. Il ne convient pas à une machine-outil de précision.
Posted: Tue Dec 07, 2021 12:35 am
by Filardo
Quelle serait la précision obtenu avec ce genre de vis a billes
What would be the precision obtained with this kind of ball screw?
