So I bought a unused/used "buildyourcnc"
centroidsupport
Re: So I bought a unused/used "buildyourcnc"
Post by centroidsupport »
Thanks for replying tblough, It goes a little beyond "limited to 20 Intercon blocks".
While correct, it's also limited to 50Kb of G-code file size, regardless of the number of "Intercon blocks" used to generate to said G-code file.
Regardless, you can do quite a lot of machining within those limitations.
centroidsupport
I see no software purchased for 0813215081 or Acorn-5081.
metalman2
CNC Control System Serial Number: 1442FC0CB1C3-0813215081
Post by metalman2 »
So I just need to purchase the license? I just include the report that I just posted when I make this purchase? Thanks again
Is my serial #5081?
centroidsupport
Yes sir.
Include the report file and you're good to go.
Please, ALWAYS use a report file when purchasing software as software purchases are non-refundable.
metalman2
Post by metalman2 »
Is the license a onetime purchase? I find the info on the website very vague.
centroidsupport
Yes, it's a one time purchase and is linked to the Acorn board itself.
If a license had been purchased for this board, I could have sent it to you.
If you purchase a license, and hardware damage occurs to your current Acorn, we will transfer the license when you return the original Acorn board.
We cannot transfer a license unless the original Acorn board is returned.
