505 invalid value
tdchoice
505 invalid value
Post by tdchoice »
Hi. I recently updated to v4.64. I am having an issue when it comes to facing parts. Not sure if I'm missing files when I updated my software. It gives me an invalid value error when I graph the part. Please help. Thanks
report_F045DA4BB842-0810181123_2021-10-20_16-46-31.zip
(658.54 KiB) Downloaded 72 times
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: 505 invalid value
Post by Nigelo »
F0 (I.e. feed 0 ipm) appears to be your problem as it must be >0
Hope this helps
Nigel
tdchoice
Post by tdchoice »
Would I have to edit F0 in every file I face because it worked fine in v4.18. I tried older files that worked before the update but not now. Interesting.
centroidsupport
Post by centroidsupport »
An update doesn't change values in existing gcode files or Intercon files. Did you re-post the files?
What are the modification dates on your files?
Please be sure to include your gcode and Intercon files (in addition to the report) when asking questions specific to a particular file.
