My Sherline Chucker lathe with Acorn control build
I decided to separate my mill and lathe build theads as not to overly confuse the dialog on the 2 machines in regards to what machine Im asking about and others looking through this thread in the future.
Re: My Sherline Chucker lathe with Acorn control
As I start getting into the final setup of my chucker lathe I wanted to ask if some of you can point me in the direction of some videos for basic setup info for a gang tool type CNC lathe. I will be setting up tools on both sides if the stock. I have lots of CNC mill experience but NO CNC lathe experience at all, I have however run a manual lathe for years and know the basics when it comes to manual work. I will lean on the documentation from Sherline but its only going to get me so far since their control is not Acorn.
Obviously, there is CNC12 Lathe manual, but I'm looking for some overview info as a starting point.
Re: My Sherline Chucker lathe with Acorn control build
Thanks, Marty provided that thread as well, a good read. gotta go through it again.
Hey all I started learning lathe set up and been looking for options for setting tool offsets for a Lathe. There is not much out there for cheep!
Anyone know of a cost effective option FYI, my machine is small so can not chuck up anything larger than 1/2 di. using 3C collet that needs to go into the spindle bore so it needs to be a really small length and diameter.
Saw this on eBay but not exactly sure what and how it would work since it has no wired connection to the control. Can someone explain what this is?
https://www.ebay.com/itm/393578867921
I’m even open to a DIY option. After doing tooling set up on the lathe only 2 times so far I’m feeling like, wow this sucks! It’s a PIA. I’m on a gang tool lathe with fixed vertical tooling offsets, the holders are located dead center to the spindle vertically but need to be indicated in, in X.
Gotta be a better way to do this even at this small scale.
Can a tool probe be located anywhere you would want to mount it like a industrial machine where the tool probe is mounted to a movable arm?
Skim cut and a micrometer are your best and most accurate bet. A skim cut takes into account tool/machine deflection. Tool setters need very rigid machines and the moveable arms are very precise pieces of kit to maintain almost zero play. Not something you'll be able to duplicate on a DIY budget.
I thinking something that is installed in the collet.tblough wrote: ↑Sun Oct 10, 2021 7:19 pm Skim cut and a micrometer are your best and most accurate bet. A skim cut takes into account tool/machine deflection. Tool setters need very rigid machines and the moveable arms are very precise pieces of kit to maintain almost zero play. Not something you'll be able to duplicate on a DIY budget.
Tell us more about the sequence of cuts that you'll do with the lathe. Franco's video showing how he uses his chucker lathe, shows a workable solution. If I were setting up a lathe for production runs, I would use raw stock that was a little oversize in diameter and length. My first cuts would trim the part to length. My second cuts would trim the part to proper diameter. Those cuts might require air cuts if there is a significant variation in the size of the raw material. Once the raw material has been trimmed to proper length and diameter, all other cuts and tools could use a standard starting offset.
-Mike Richards
It would need to be a dedicated tool holder. Most collets are +-0.001" accuracy.
Im following the manual exactly. I'll say one thing for sure it's sure not very elegant, Leaning electronics is one thing, LOL but learning Lathe tool offsets in CNC12 of darn right clunky! A simple step-by-step wizard would be nice to streamline the process. Hopefully, I won't offend anyone but the process could be streamlined for the newbies! Im still wrapping my head around the process.Richards wrote: ↑Mon Oct 11, 2021 7:44 am Tell us more about the sequence of cuts that you'll do with the lathe. Franco's video showing how he uses his chucker lathe, shows a workable solution. If I were setting up a lathe for production runs, I would use raw stock that was a little oversize in diameter and length. My first cuts would trim the part to length. My second cuts would trim the part to proper diameter. Those cuts might require air cuts if there is a significant variation in the size of the raw material. Once the raw material has been trimmed to proper length and diameter, all other cuts and tools could use a standard starting offset.
