Good afternoon,
newbie question,
just ran a facemill op. I want to step it down 20 thou and run it again at a slower feedrate (manual feed override)
How do I adjust my work coord system down 20 thou so I can just rerun the code?
Also, how do I manually tell it to go to home? (G0 X0 Y0 Z0)? Where can I type code in?
Thanks!
newb question, how do i rerun code 20 thou lower?
Re: newb question, how do i rerun code 20 thou lower?
The Centroid CNC12 manual is located here: https://www.centroidcnc.com/centroid_di ... -v4.20.pdf
- CNC Control System Serial Number: 1702
With the mill offset so it will not jog into the part move the head down to .020" below the original Z. Reset Z axis zero on the control panel. This is how I do it if it's only for 1 part
