Software to Convert to .g file
Re: Software to Convert to .g file
sheetcam works for plasma
- CNC Control System Serial Number: 0035ff8a2d8f-0813203616
Vacuum turn on/off
Thanks everyone for your help. now I am trying to make the plasm turn on and off automatically from the g code but I have not been able to place the necessary commands to do that action
How Can i do that?
How Can i do that?
As Keith stated, Sheetcam is one option of MANY software programs available. It's fairly inexpensive as well. Do a Google search for cnc plasma cutting software. There's A LOT more to cnc plasma cutting than simply converting a DXF drawing file to g code. Great, now you have some g code from your drawing, how are you going to tell the plasma cutter what you are cutting? what amperage to use? how fast to cut the material? how will you tell it the pierce height? cut height? there's torch height control, kerf compensation, lead in and lead outs, etc.
Please look into some plasma cutting software, you can't do it alone with a DXF converted drawing.
This site may be of benefit to those with CNC Plasma machines:
https://www.plasmaspider.com/
Marty is correct, this is a great plasma cutting forum/website with lots of info and knowledgeable people on there to help. I also operate a 5x10 Shop Sabre plasma table with a Hypertherm 85 and that site has been helpful in the past. Hoping to someday switch it over to an Acorn plasma controller.martyscncgarage wrote: ↑Tue Oct 19, 2021 9:31 pm This site may be of benefit to those with CNC Plasma machines:
Here's a pic of my cnc plasma that was purchased used at a tool auction. It currently has the WinCNC controller.
