notepad ++
- CNC Control System Serial Number: 402E71D16818-0414214669
notepad ++
Good afternoon, I'm following the installation bulletin for notepad++ but I'm missing something that impedes me to have a successful install please see the attached picture. I cannot select file associations.
Re: notepad ++
It states in the box that you need to be in administrator mode to use that option. Exit Notepad++ and then run as administrator. To do this right click on the Notepad++ icon on your desktop and select "Run as Administrator" and then go back to the "preferences" and it will no longer be grayed out and you can make your selections.
Re: notepad ++
Thank you.ShawnM wrote: ↑Tue Sep 14, 2021 6:21 pm It states in the box that you need to be in administrator mode to use that option. Exit Notepad++ and then run as administrator. To do this right click on the Notepad++ icon on your desktop and select "Run as Administrator" and then go back to the "preferences" and it will no longer be grayed out and you can make your selections.
