Hi
I am building a 3 axis desktop machine. I was going to use Mach for a controller until I came across Acorn. I have NOT purchased an Acorn board but would like to evaluate CNC12, in particular Intercon conversational. I have downloaded and installed CNC12 but it will not run without connecting to Acorn.
Is it possible run CNC12 without connecting to Acorn?
Can I run CNC12 Without Connecting to Acorn?
I'm passionate about Machining
Pursuing the cutting edge ⛏
Re: Can I run CNC12 Without Connecting to Acorn?
You can download the CNC12 version for servo systems https://www.centroidcnc.com/centroid_di ... v420-D.exe
That will let you choose a demo version that you can run stand-alone.
