no x or y movement on new acorn install
Re: no x or y movement on new acorn install
So axis 1 and axis 4 works on Acorn. Axis 2 and axis 3 do not?
Did you miswire anything?
Perhaps you got a power surge and damaged it
Are you using the DB25 or the headers for axis control?
jbernis
CNC Control System Serial Number: acorn-4932
Post by jbernis »
Wiring is all correct,i am using the the header connectors. As per my first post i did have a loss of power during a restart which is when this started.
jbernis
Post by jbernis »
I came in this morning and swapped all my connections to db 25 connector and the results are the same , no drive on 1 and 2
For giggles and grins, please post a fresh report
Also, have you been making all your changes from within the Wizard or have you been getting into the parameter settings?
jbernis
Post by jbernis »
Hi guys
Marty,
I have been at it again. First off i have been making changes in the wizard. Today i emailed Keith with centroid and he asked to perform a few things then post a report. At the moment all connections are as they were when i started. after doing what Keith suggested the outcome is the same );. I will post this report and see what you guys come up with next.
Thanks Jason
jbernis
Post by jbernis »
jbernis
Post by jbernis »
back at it, just checked output status of enable terminals,
ena led red,
axis 1=23.6v
'' 2=150 mv
'' 3=125 mv
ena led green,
axis 1=23.6v
'' 2=175 mv
'' 3=23.6v
Centroid_Tech2
Post by Centroid_Tech2 »
It sounds like there may be some issues on the Acorn board itself.
https://www.centroidcnc.com/centroid_di ... ranty.html
