Wring up Omron encoder
Posted: Thu Sep 02, 2021 11:22 pm
by BillB
Hey all,
Have a question about wiring up my Omron encoder. Using Acorn Drawing S14954 V5 & wiring schematic for the Omron encoder.
I'm stuck on the blue wire and am not sure what pin it goes to. Does it go to Pin 1 N/C OR Pin 2 COM? BTW: what does N/C mean on a wiring diagram?
And if you can confirm that last pin is just left blank with no wire, Correct?
Re: Wring up Omron encoder
Posted: Fri Sep 03, 2021 7:54 am
by eng199
Blue goes to pin 2.
NC or N/C is "no connection".
DB9 pin 1 is a spare, it has no function.
Posted: Fri Sep 03, 2021 1:55 pm
by BillB
eng199 wrote: Fri Sep 03, 2021 7:54 am Blue goes to pin 2.
Awesome, thank you!
Posted: Sat Sep 04, 2021 2:53 am
by BillB
Ive just added the DB9 connector, Is there any way to test the encoder without hooking up to Acorn and PC?
Posted: Sat Sep 04, 2021 7:24 am
by tblough
Posted: Sat Sep 04, 2021 5:30 pm
by BillB
thanks
Posted: Thu Sep 16, 2021 3:27 am
by BillB
Hey guys does my encoder need to be grounded on the DB9 connector housing or is the Com wire also the ground like shown in the manual?
Posted: Thu Sep 16, 2021 7:07 am
by tblough
Two separate things. The COMmon wire for the electrical signals needs to be connected to pin 2, and the shield needs to be soldered to the connector shell.
This is what is shown in the manual in both the diagram and the photo.
Posted: Thu Sep 16, 2021 9:04 pm
by BillB
tblough wrote: Thu Sep 16, 2021 7:07 am Two separate things. The COMmon wire for the electrical signals needs to be connected to pin 2, and the shield needs to be soldered to the connector shell.
Just making sure, thank you.
