I am thinking of adding a 4th axis for gear cutting with my Acorn controlled mill. Anyone have any suggestions? Thanks.
John
4th Axis?
Re: 4th Axis?
Without more information, we don't have much to go on.
For gears I'd use a stepper motor controlled rotary table with a tail stock. I have 4 inch tables for the Sherline mills and a 6 inch table for the Tormach. As long as the stepper motor driver has step and direction connections (most, if not all, do) then it should work.
Re: 4th Axis?
None of Centroids products will do gear hobbing yet. You can certainly use a 4th axis as a positioner when using a form cutter.
