Hi guys, I’m new here, I have my acorn connected to a router and I followed the recommendations described in the touch off plate topic, and my touch plate worked fine, until I was changing the connector, I didn’t turn off the machine while I was soldering the new connector (I know, I screwed up ), now the touch plate doesn’t work, what I should do?, I checked the input port using the Estop and it works well.
Please help, greetings from Colombia
Touch off plate problem after soldering
