ether 1616 not recognized <resolved>
n2xd
CNC Control System Serial Number: 0943
Post by n2xd »
Trying to install ether1616 but it is not recognized. Please ignore the dates on the pictures as the camera does not get used much and has to be recharged every time I want to use it. Any help would be appreciated. Thanks.
John
eng199
Re: ether 1616 not recognized
Post by eng199 »
Not showing up in wizard, or something else?
There is a lot of information in this thread:
viewtopic.php?f=60&t=5812&hilit=eth1616
You might want to do something about the exposed foil and braid on the shielded wires above your Acorn board before something shorts out.
n2xd
Post by n2xd »
It's not showing up in wizard.
Everything will be set right I am still trying to get every thing working together.
Richards
Post by Richards »
What lights do you have on your network switch? It looks like jumper A0 is in place, so the board should be at IP address 10.168.41.3. Your PC should be at IP address 10.168.41.1 and your Acorn should be at IP address 10.168.41.2. What happens when you ping those addresses? (See page 4 of the Ethernet 1616 setup guide.)
I cannot see how your power supply outputs are wired to the 1616 board. Verify that you have the proper voltages going from the power supply to the 16X16. (See page 3 of the Ethernet 1616 setup guide.)
-Mike Richards
n2xd
Post by n2xd »
Thanks for the reply. The fault has been corrected. I had to change the ether port settings(on the Centroid supplied computer ) to the correct ones. Once again thanks for your offer to help.
John
