table moving more then dro shows
Posted: Sat Jul 31, 2021 12:12 pm
Hy guys,
I left my machine to sit a while and when I turned it on again, I found a problem.
I wanted to move 100 mm and the table moved 130mm. This is happening on all axis. so I don't assume that it is steppers.
I did check to set on steppers and I have it set to 6400 steps for rev. same as in wizard, my ball screw has 5mm pitch same as I have it set up in the wizard.
I did try to restore different reports from the past and they all showed the same problem...
and have no idea what is going on as I have all settings the same as I was using the machine before...
