Hi Everyone.
I know this was covered on an earlier thread but I am now having the exact same issue since upgrading to v4.64 . I have followed the previous thread and its instructions and here is what's happened / happening.
I have downloaded v4.64 from the centroid website here: https://www.centroidcnc.com/centroid_di ... taller.zip
I have renamed my v4.50 folder then installed v4.64 MILL as a new install, I have a milling machine and a PRO licence. I have tried to restore from a restore file and got the spindle problem, I then uninstalled cnc12 and reinstalled a completely fresh install, then I manually entered in all my parameters (I have photos of all previous settings from v4.50) in case it was an error in the restore file but it is still occurring.
When I turn on the machine from a power down state and everything has booted up and loaded, I can run the spindle, as soon as I try to do a tool change either from MDI or a NC program I loose all spindle responsiveness. I am running 0-6v analogue with Outputs controlling FWD and REV. When this error happens the outputs don't function and I get no voltage change at the spindle control terminals on the acorn board. to get the spindle to function again I must power down the acorn board and restart cnc12.
I have attached my most current report.zip file.
Help me cncKeith your my only hope (that's a star wars reference )
Thank you kindly in advance
Russell
CNC12 Spindle becomes unresponsive - Take 2
- CNC Control System Serial Number: 0479B7ADC680-0210202964
- report_E0623462B3E9-0511214782_2021-07-28_16-31-56.zip
- (624.08 KiB) Downloaded 57 times
Re: CNC12 Spindle becomes unresponsive - Take 2
lots of probe tripped messages in the error logs, looks like the control thinks you have a probe in the spindle therefore the spindle won't turn on. thats my guess.
Take the time to take screen shots of all your Wizard pages and print them out, from the previous working version.
Do a FRESH install of CNC12 4.64.
Using all your printed screenshots, carefully hand key in all the machine settings.
Leave out probe inputs (Keith suggested you have have some probe input issues) until you get the machine fully functional again WITHOUT probing.
It should take you 30 minutes tops. Its not that hard to do a fresh install from scratch.
Learn to read your error logs, F7 Utility, F9 Logs, F1 Errors. These messages also pop up in your dialog message box on the main CNC12 screen:
The line with the Temperatures is the first I have seen, have you been playing with parameter values?
(1) 07-28-2021 13:55:40 930 Log Level Configuration file not found... Creating new configuration.
(1) 07-28-2021 13:55:40 933 Log file initialized
(1) 07-28-2021 13:55:40 199 CNC Started
(1) 07-28-2021 13:55:46 335 Emergency stop released
(1) 07-28-2021 13:55:48 CNC12 Acorn Mill v4.64
(1) 07-28-2021 13:55:48 9033 Reset Initiated, Press Reset to Clear
(1) 07-28-2021 13:56:07 Created Weekly Report
(1) 07-28-2021 13:56:07 4032 Reset Cleared
(1) 07-28-2021 15:41:49 204 Exiting CNC...Normal Exit (66)
(1) 07-28-2021 15:43:03 199 CNC Started
(1) 07-28-2021 15:43:10 CNC12 Acorn Mill v4.64
(4) 07-28-2021 15:43:12 9033 Reset Initiated, Press Reset to Clear
(4) 07-28-2021 15:43:24 4032 Reset Cleared
(1) 07-28-2021 15:54:58 302 Moving...
(1) 07-28-2021 15:55:00 313 Waiting for dwell time (M26)
(1) 07-28-2021 15:55:44 306 Job finished
(1) 07-28-2021 15:56:32 204 Exiting CNC...Normal Exit (66)
(1) 07-28-2021 15:56:39 199 CNC Started
(1) 07-28-2021 15:56:43 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 07-28-2021 15:56:46 CNC12 Acorn Mill v4.64
(4) 07-28-2021 15:56:47 9033 Reset Initiated, Press Reset to Clear
(4) 07-28-2021 15:56:49 4032 Reset Cleared
(1) 07-28-2021 15:57:57 907 Y axis travel exceeded
(4) 07-28-2021 15:58:14 907 X axis travel exceeded
(1) 07-28-2021 15:58:22 FAST_JOG_SELECTED
(1) 07-28-2021 15:59:21 999 Parm #220 modified: 0.00000 -> 1.00000
(4) 07-28-2021 15:59:21 999 Parm #221 modified: 10.00000 -> 1.00000
(4) 07-28-2021 15:59:21 999 Parm #222 modified: 0.05080 -> 0.02540
(4) 07-28-2021 15:59:21 999 Parm #223 modified: 1000.00000 -> 800.00000
(4) 07-28-2021 15:59:21 999 Parm #226 modified: 20.00000 -> 10.00000
(4) 07-28-2021 15:59:21 999 Parm #227 modified: 1.00000 -> 95.00000
(1) 07-28-2021 16:01:18 8040 WARNING: PROBE TRIPPED
(1) 07-28-2021 16:01:18 9042 Probe Cleared
(4) 07-28-2021 16:04:58 8040 WARNING: PROBE TRIPPED
(1) 07-28-2021 16:04:59 341 Probing Cycle finished
(4) 07-28-2021 16:05:00 9042 Probe Cleared
(4) 07-28-2021 16:06:19 8040 WARNING: PROBE TRIPPED
(4) 07-28-2021 16:06:21 9042 Probe Cleared
(4) 07-28-2021 16:06:51 8040 WARNING: PROBE TRIPPED
(4) 07-28-2021 16:06:51 9042 Probe Cleared
(1) 07-28-2021 16:13:45 304 MDI...
(1) 07-28-2021 16:13:48 307 Operator abort: job cancelled
(1) 07-28-2021 16:17:06 417 Abnormal end of job
(1) 07-28-2021 16:18:25 204 Exiting CNC...Normal Exit (66)
(1) 07-28-2021 16:18:30 199 CNC Started
(4) 07-28-2021 16:18:34 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 07-28-2021 16:18:37 CNC12 Acorn Mill v4.64
(4) 07-28-2021 16:18:37 9033 Reset Initiated, Press Reset to Clear
(4) 07-28-2021 16:18:39 4032 Reset Cleared
(4) 07-28-2021 16:20:23 8040 WARNING: PROBE TRIPPED
(4) 07-28-2021 16:20:23 9042 Probe Cleared
(4) 07-28-2021 16:20:26 8040 WARNING: PROBE TRIPPED
(4) 07-28-2021 16:20:27 9042 Probe Cleared
(1) 07-28-2021 16:21:50 916 Unexpected probe contact
(1) 07-28-2021 16:21:51 319 Probing Cycle cancelled
(4) 07-28-2021 16:21:51 8040 WARNING: PROBE TRIPPED
(4) 07-28-2021 16:21:57 9042 Probe Cleared
(4) 07-28-2021 16:24:11 8040 WARNING: PROBE TRIPPED
(4) 07-28-2021 16:24:18 9042 Probe Cleared
(4) 07-28-2021 16:24:29 907 Z axis travel exceeded
(1) 07-28-2021 16:26:34 417 Abnormal end of job
(1) 07-28-2021 16:28:19 Temps: X=0.0° Y=0.0° Z=0.0° A=0.0°
(4) 07-28-2021 16:28:28 9033 Reset Initiated, Press Reset to Clear
(4) 07-28-2021 16:28:31 4032 Reset Cleared
(1) 07-28-2021 16:31:17 5038 SPECIFIED SPIN SPEED < MIN SPIN SPEED
(1) 07-28-2021 16:31:56 Creating report...
That just means he pressed Alt-T at some point.
In a closed-loop torque-mode control, CNC12 would display its current servo motor temperature estimates. On an open-loop or velocity-mode or position-mode control, CNC12 has no way of guessing at motor temperatures, but Alt-T still triggers the message.
Thanks for that info Marc!cncsnw wrote: ↑Sat Jul 31, 2021 8:06 pm That just means he pressed Alt-T at some point.
