Jog increments
rlaury
Jog increments
Post by rlaury »
Hi All:
I'm using Centroid Acorn on a PM-728VT with Clearpath servo's.
I've seen several video's where thy seem to mention a jog increment
of .0001. In my setup, the smallest increment I have is
.001". Is there a way to have .0001"? It would be handy to have
when using a touch probe and close work.
RonL
polaraligned
Re: Jog increments
Post by polaraligned »
Check parameter #40. It holds the control's basic jog increment size. Default is .0001" and will jog that amount with the X1 jog key.
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: Jog increments
Post by Nigelo »
Simplest and preferred method with Acorn is to use the Wizard - Go to the Axis configuration section and enter your requirement (i.e. 0.0001) in the x1 Linear Jog Increment box.
Whilst in the Wizard, also review the Touch Devices - Probe and change as required
hope this helps
Hope this helps
Nigel
