I have to apologize up front for asking these silly questions. NP++ is not something I am familiar with at all. But I do appreciate the help.
I somehow changed the look of NP++. How do I get it back to the default screen?
Need more NP++ help
Re: Need more NP++ help
Go to settings, style configurator, then you can see there is an option called select theme. Select default theme and save it. Close and restart. You may also have changed some global overrides and you can uncheck those.
You could also try deleting the "stylers.xml" from C:\Users\YourUserName\AppData\Roaming\Notepad++.
Scott
Thank you! what a learning curve. One more question. when you go to Plugins, NPP, execute. What is the command string that follows that and what is it supposed to do?
Perhaps this will help... Configuring NP++ https://www.centroidcnc.com/dealersuppo ... ds/294.pdf
Scott
I think I have NPP working now and I am working on editing a macro on the MPG. Would someone send me a simple X or Y movement that I could assign to the macro one button on the wireless controller. Then I might be able to do one of my own.
