The ghost is back in the machine
It appears the ghost is back. We keep getting errors. Everything has been fine until yesterday. Since the first time: bearings have been replaced, the ethernet cable as well as the computer motherboard.
- report_0479B7E7BDC2-0205202948_2021-06-05_17-21-57.zip
- (2.03 MiB) Downloaded 112 times
Re: The ghost is back in the machine
Could there be a problem with the Beagle bone?
would be a good easy test. i have seen a few (out of many thousands) of BBG ethernet adapters that had issues
Is there a simple way to test the board? Thanks
Yes, replace it with a known good or new unit. I usually have a couple on the shelf.
I haven't really seen them go bad, but have had a few bench testing incidents, and I didn't want to have to wait for them to be shipped. Besides, they're cheap
It seems there are a variety of bones to choose from; black, blue, green...is there ONE that is compatible or will all of the above work?
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
That's a BB Black Industrial, I believe the only one that works is the Seeed Studio BB Green.
https://www.seeedstudio.com/Seeed-Studi ... Green.html
Scott
No, you want the BBGreentuffduck wrote: ↑Sun Jun 06, 2021 5:44 pm Will this one be okay?
https://www.digikey.ca/en/products/deta ... 3/12342853
There is also at least two versions of the BeagleBone green, one has wifi on it. Maybe Keith will list the correct model that Centroid uses.
