delicate end-of-travel settings
- CNC Control System Serial Number: ID0035FF621C27-0414214659
I would like to modify the withdrawal stroke after the first touching of the limit switches. 1 / first touch of the limit switch then withdrawal of 2mm and retouch at slow speed. what parameter or macro should I change? Thanks for your help
Re: delicate end-of-travel settings
cncm.hom. Easy access via the wizard
In CNC12 version >= 4.20 for servo systems, you can set a distance in Machine Parameter 180. This will be the maximum distance to back off, after the switch trips, while waiting for the switch to clear again. I don't know if this is the same for Acorn. Speed is controlled by the slow jog rate for both Servo and Acorn
