Hi All,
I'm trying to get the Autosquaring to work on my machine. I have the Y-Axis motors paired. All NPN NC proximity switches are wired up in series with Input #1 as "HomeAll" and Input #2 as the slavedhomeinput.
I followed the axis pairing and homing guide to the T! The slave switch is being triggered first and the master is about 0.6mm further past. I have the gantry moving in the negative Y direction for homing.
Now my problem arises when I run the homing macro. Z Axis homes fine. Then X axis. Y axis moves in negative direction until the slave switch is tripped. The axes un-pair and then it tries to move the Y master on its own. I can see the Y Machine Co-ordinate changing but I don't have any physical movement. The macro never finishes running because the Y master never moves, thus not tripping the master home switch.
Note, I have the Y Master drive and Y Slave drive ENABLE pins jumpered. (I'm using StepperOnline CL57Y drivers).
I've attached a picture of where the macro is failing to physically drive the Y master to the master home switch. (I pressed Feed Hold in order to stop the Y axis value from changing during the screenshot).
When I re-pair the axes manually the drives work fine.
Autosquare not completing <resolved>
- CNC Control System Serial Number: 0035FF6216B7-0206214337
- report_0035FF6216B7-0206214337_2021-05-29_18-47-05.zip
- (651.15 KiB) Downloaded 78 times
Re: Autosquare not completing
Pro License installed?
Report shows PRO Router.
Yes PRO Router license.
id try not using the enable as an experiment.
I disconnected the ENABLE jumper between the two Y axis drives. This fixed my problem! The autosquaring macro now completes as expected. Thanks everyone!
