I was wondering ifthe eth 1616 i/o board could be used as a fault monitoring board for the Tecnic Clearpath fault circuits? I have several unused inputs that I won't use? would it work?
Gary
Eth 1616 as a relay board
Re: Eth 1616 as a relay board
Yes. That's what it's designed for, to add Features via additional I/O
- CNC Control System Serial Number: C143226
If I bring in each motor's HLFB signal to 4 inputs of the eth1616 board what function do I select in the wizard to shut down the machine. I haven't seen any examples on schematics that show its use for that purpose. It sounds too easy.
Gary
Gary
1st, 2nd, 3rd, 4th axis drive ok or alarm
Thank you for the reply. I've seen several pictures of using a seperate relay cards as I did in Mach 3 but didn't think of using the extra inputs for the same thing. Thank you for the help
Gary
Gary
