Looking for way to set G54 values with macro
Chris D
CNC Control System Serial Number: ACORN 4447
Post by Chris D »
Greeting all,
I am sure this is simple, I just can't find the system variable or parameter to write the data to.
Within a macro, I want to write a value to the Z register of G54. I am using a G10 H--- R---- to write to tool length offset registers, but can't figure out how to write to the work offsets.
Thanks!
Chris D
Sword
Re: Looking for way to set G54 values with macro
Post by Sword »
For whatever work offset you're in, G92 X(value) Y(value) Z(value).
In a macro for locating WCS with a cross hair laser, I've done it like this (abbreviated version)...
#101 = 1           ; Default WCS G54
#102 = 5           ; Length of time to wait for M225 message
N200
M224 #101 "What WCS would you like to set? (Enter 1-6)"
IF [#101 < 1] || [#101 > 6] THEN GOTO 200
E#101              ; Set the chosen WCS
G92 X0 Y0
M225 #102 "XY LOCATION SET FOR WCS #%.0f" #101
Scott
Chris D
Post by Chris D »
Awesome! Thank you Scott!
Another method:
If you know what value you want to put in the G54 Z coordinate, but you have not necessarily moved the axis to that place, you can just assign the desired location in system variable #2701. See system variables #2400-#3218 in Chapter 11 of the Operator's Manual.
Chris D
Post by Chris D »
Thanks CNCSNW, I used that technique. The wording "ACTIVE" threw me off in the System Variable description, however, it does do what I wanted!
Thanks!
Chris D
