Hi all,
I'm modeling my control cabinet in solidworks for a cnc mill conversion, and am looking for a decent model of the acorn board and relay board. I could wip one up my self, but this seems like something someone in the forum has probably done, and I'd like to save time. I looked on the forum and in the usual spots for it (e.g. GrabCAD) with no luck. Does anyone have a decent model they would be willing to share?
CAD Model Files for the Acorn MCP
Re: CAD Model Files for the Acorn MCP
Here's the model I created for my test panel. You should be able to pull the various components off it to use as you wish.
- AcornTestSetup.zip
- (2.95 MiB) Downloaded 75 times
Thanks @tblough. I needed a model with the connectors on it, so I ended up making the uploaded files.
- Centroid Acorn STEP.zip
- (7.1 MiB) Downloaded 67 times
Added model to grabCAD. Here is a link https://grabcad.com/library/centroid-ac ... endering-1
Finished up the model to where its good enough for what I need. This should be good enough for most peoples' purposes.
Cheers
Cheers
- Centroid Acorn Solidworks Assembly.zip
- (7.1 MiB) Downloaded 71 times
