Door safety switch
LenelyWolf
Re: Door safety switch
Post by LenelyWolf »
Allin1Chris wrote: Mon May 17, 2021 2:19 pm Hi LenelyWolf,
Attached is a modified version of your PLC, that should resolve the delay issue. Let us know how it works!
To Install, Extract the contents of the .zip directly into your C:\cncm folder and overwrite files. Powercycle your acorn after installing the files and restart the software.
Thanks… i will try it tomorrow and i will let u know.. do i need to compile it or is overwriting files in cncm folder good enough?
Allin1Chris
Post by Allin1Chris »
Its Pre-compiled, overwriting will be good enough.
Centroid PLC Tutorial Videos
LenelyWolf
Allin1Chris wrote: Mon May 17, 2021 4:41 pm Its Pre-compiled, overwriting will be good enough.
Hi
Just try that and unfortunately it doesn’t work. I have unzipped and overwritten all files in my cncm folder, restarted my machine and my pc and it still ran the first second or so. I have even tried to compile it again and it is still the same. My program is really simple testing one
G0 X-50.
G04 P1.
G0 Y-50.
G04 P1.
G0 X-5. Y-5. Z-5.
M30
ALWAYS, ALWAYS, ALWAYS Post a Fresh Follow up Report.
That way Chris can take a look at it and see what you did or didn't do, or what the software IS or ISN'T doing
LenelyWolf
martyscncgarage wrote: Tue May 18, 2021 12:05 pm ALWAYS, ALWAYS, ALWAYS Post a Fresh Follow up Report.
Ok… here it is
report_E062347D88E8-1215204216_2021-05-18_13-24-57.zip
(652.88 KiB) Downloaded 76 times
Allin1Chris
LenelyWolf,
Attached is another modified PLC for the door. Same as before, extract to your directory and overwrite files. It is pre-compiled.
Let us know if it works out!
Acorn_Door_Fix2.zip
(156.13 KiB) Downloaded 92 times
LenelyWolf
Allin1Chris wrote: Wed May 19, 2021 3:22 pm LenelyWolf,
Thanks… will let u know.. however I’ve added licence to my cnc12 today so is it save to overwrite the files anyway?
Allin1Chris
Yes, the PLC should not effect your license status in software. If it does, you should still have the file centroid sent you to re-activate it.
LenelyWolf
Allin1Chris wrote: Wed May 19, 2021 4:48 pm Yes, the PLC should not effect your license status in software. If it does, you should still have the file centroid sent you to re-activate it.
So good news… the second fix works nicely. Thank you
