Page 2 of 2
Re: Unstabe rpm with Lenze drive
Posted: Sun May 02, 2021 1:47 pm
by LenelyWolf
martyscncgarage wrote: Sun May 02, 2021 1:44 pm The capacitor may help
Thanks... already ordered one so I’ll try it.. I have also ground both ends of that shielded cable but that didn’t help.
Posted: Sun May 02, 2021 1:50 pm
LenelyWolf wrote: Sun May 02, 2021 1:47 pm
Unground both end.
Also try just a pair of 18gauge wires. You have nothing to lose while you are waiting for the cap
Posted: Sun May 02, 2021 2:28 pm
by LenelyWolf
martyscncgarage wrote: Sun May 02, 2021 1:50 pm
Unground both end.
Ok so this helped. I have ungrounded both ends and it was better but not perfect. Then I replaced cable for 18awg and now it runs nice and stable. Thank you. I really appreciate your help. Can you also explain why making it better actually made it worst.. I don’t get it
Posted: Sun May 02, 2021 3:26 pm
I suspect the larger wire added a bit of capacitance.
I can't explain it really. But glad it helped you.
Posted: Sun May 02, 2021 6:12 pm
by polaraligned
Sounds like you had a bad wire. Maybe the wire had some corrosion and was not making a good connection.
(.5mm) 24 awg is a bit small and delicate. The added capacitance from increasing the size is trivial.
Posted: Sun May 02, 2021 6:33 pm
by LenelyWolf
polaraligned wrote: Sun May 02, 2021 6:12 pm Sounds like you had a bad wire. Maybe the wire had some corrosion and was not making a good connection.
I have inspected the cable by taking it apart and didn’t see any visible damage. Well at least it is fixed. Should I still install that capacitor?
Posted: Sun May 02, 2021 8:33 pm
by polaraligned
LenelyWolf wrote: Sun May 02, 2021 6:33 pm I have inspected the cable by taking it apart and didn’t see any visible damage. Well at least it is fixed. Should I still install that capacitor?
I wouldn't bother.
Re: Unstabe rpm with Lenze drive (Resolved)
Posted: Mon May 03, 2021 10:11 am
It shouldn't hurt either. Acorn does not have the same spindle analog circuitry that Oak and All in One do.
