You can get a replacement Acorn for $199 through Centroid's Swap-out Program:
https://www.centroidcnc.com/centroid_di ... ranty.html
Acorn burned down < strand of hookup wire on board>.
Re: Acorn burned down < strand of hookup wire on board>.
https://www.centroidcnc.com/centroid_di ... ranty.htmldlewis69 wrote: ↑Tue Sep 20, 2022 7:41 amTrouble shooting a new build here. Passed all my bench test but it seems I have blown the output like you mentioned here. Is that a new BBB or new Acorn or can I fix? TIAmartyscncgarage wrote: ↑Sat May 01, 2021 2:54 pm So, your Lenze drive is a DC spindle drive.
DO you know if it has built in SIGNAL Isolation?
It is not a standard VFD.
IF your Acorn will no longer pass the spindle bench test, then my guess is that you blew the Spindle Analog Output on Acorn.
Please explain with a sketch how you wired Acorn to the Lenze drive.
Look at the Swap Out Program
