I'm having a problem with the control panel not starting. The message is attached
EDIT - I ended up reinstalling and got the VCP back
NEED HELP - VCP not starting <self resolved>
- vcp.JPG (13.65 KiB) Viewed 1158 times
- report_402E71CADC40-0323214550_2021-04-30_11-23-13.zip
- (603.47 KiB) Downloaded 68 times
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
Re: NEED HELP - VCP not starting
Usually having to do with a corrupted file or anti-virus program holding the file open. Remove any anti-virus programs on the computer and copy that file from a report zip. If that doesn't fix it, reinstall CNC12.
I suspect that it may have been caused by logging in to the computer remotely... When I reinstall CNC12 is there a way to get all my tools back. At this point I am bench testing so I don't have a lot of collateral but someday it would be nice to get everything back. I tried loading a previous backup but that didn't work
Re: NEED HELP - VCP not starting <self resolved>
You just need to copy two files from a previous save report. The Tool library file (for a mill) is cncm.tl and contained in the c:\cncm folder. The offset data for each tool (Offset Library) is held in cncm.ol in the same folder.
These files are saved in the report zip, but are not restored automatically during a restore report.
