Hello, I don't know which wiring diagram to choose to wire my LICHUAN LCDA86H drivers and what are the advantages of choosing 24v or 5v for LICHUAN LCDA86H?
http://www.t2cnc.hu/downloads/Lichuan/L ... Manual.pdf
thank you
Re: 24v or 5v for LICHUAN LCDA86H
id use the DB25 connector with breakout board with these drives.
in general use db25 for stepper drives, use screw terminals for AC servos.
- CNC Control System Serial Number: ID0035FF621C27-0414214659
so I wire like the diagram S15032 LEADSHINE CS-D508? Just enable it on terminal block H2 and H3. ? Thanks
Correct....
