I just started up my CNC router running Centroid and received a message regard the pendant no being connected. It said something to the effect of needing to upgrading to the Pro Version. The message went away and I do not have the exact language.
This is a machine I bought with Centroid installed and it has worked so well that I have really not put a lot of effort into learning much about Centroid. I'm good with manuals... but right now I was just checking to see if this is something obvious or a change in licensing.
Thanks.
MPG Pendant Stopped Working - Licensing (Resolved)
- CNC Control System Serial Number: 4C3FD33AB588-0107202815
Re: MPG Pendant Stopped Working - Licensing
It is working now.
I went into the wizard and it was not configured. I added it back and it seems to be working fine. Not sure what happened.
ALWAYS post a report when asking for help. It has all the machine's parameters and how it was set up. You should most certainly keep a copy of it and the CNCM or CNCT directory on a thumb drive.
To get a report, from the main CNC12 screen, press F7 Utilities, F7 Create Report
