Hey,
i have just upgraded to router pro and i have been trying to figure out how to program the vcp buttons for a while now and im struggling.
i have read through the guides.
i just want the stock router buttons to work, specifically, "reset home", "park" and the "set wcs x y 0" "go to machine 0"and go to wcs xy0
are they like standard macro codes that someone could just to me and i paste in orrr?
whats the easiest way to do it?
see attached report if needed
thanks.
vcp button help
- CNC Control System Serial Number: B0D5CCFD5C69-0822170084
vcp button help
- report_B0D5CCFD5C69-0822170084_2021-04-14_11-25-47.zip
- (695.5 KiB) Downloaded 73 times
Re: vcp button help
The stock router buttons do work out of the box so to speak.antpdrake wrote: ↑Tue Apr 13, 2021 11:36 pm Hey,
thanks.
They work after you have reset, CNC12 software is on line, homed the machine, set your part zeros.
Can you take a video and upload it to YouTube, mark it unlisted and SHARE a link here so we can understand what is going on?
The Virtual Control panel can be customized, but it doesn't have to be to use it.
Manual:
viewtopic.php?f=60&t=1043
Video:
Re: vcp button help
like marty says these work as is.."reset home", "park" and the "set wcs x y 0" "go to machine 0"and go to wcs xy0 sounds like you haven't home'd the machine out yet.antpdrake wrote: ↑Tue Apr 13, 2021 11:36 pm Hey,
thanks.
Re: vcp button help
Reset home was done when Cnc12 booted up, if that's what you mean?
See this video
See this video
Re: vcp button help
Did you happen to upgrade to 4.64 by restoring a an old report over the top of the new install?
Re: vcp button help
hi, your problems are from the use of a Mill report.zip with the Router software.
Router CNC12 installation instructions start on page 3 here.
DO NOT use the "Restore report" method , do not use a Mill (or Lathe) “report.zip” file with Router CNC12. In future versions of CNC12 Router, updating will be a simple matter of using ‘restore report’ but for this very first version (v4.64) Router needs to be setup with the Wizard as a clean fresh install (not using the restore report method).
Re: vcp button help
ahhh yes, oops.
do i need to uninstall and start again?
thanks
thanks
Re: vcp button help
Take screen shots of your Wizard pages using windows snipping tool. The uninstall CNC12. Delete the directory. Then install a fresh copy of CNC12. Then using your screen shots, hand key in the settings in each wizard screen.
