(open) Error saving WCS information
Re: (open) Error saving WCS information
How did you change to a different PC? With a full, new install of CNC12, or by copying the old CNC 12 installation or restoring from a report?
Try this in a different PC starting with a full install of CNC 12 using the Wizard screens to enter your configuration information. Do not copy any files from the other PC - including reports.
Gansen911
Post by Gansen911 »
Yes I did restore the report. I did delete the cncm.wcs when I did that.
I will take pictures of all my pages in the wizard and uninstall cnc12 and delete the cncm folder. Then reinstall cnc12 and not restore the report. Enter in all my settings in the wizard and try again.
avp
CNC Control System Serial Number: E062346A1C67-0716214939
Post by avp »
Let me know if that route works for you. I have a similar issue with the error saving tool offset library file.
Bill
Gansen911
Post by Gansen911 »
Did not work. I unstilled CNC12, deleted the CNCM folder, reinstalled form the centroid web site, set everything up in the wizard, and seeing the same types of problems. I am now not convinced I have a corrupted hard drive on my other PC as of now. Where do I go from here? Could the problem be the acorn board itself since this has been a problem from day one? Attached is my new report.
please post fresh report.zip and a copy of the g code program (if you are getting errors when loading/running the g code program) thanks
fyi...Acorn hardware would not cause this issue.
Windows not allowing a folder or file to be written (or read) would.
Gansen911
Post by Gansen911 »
Attached is my report after the new fresh install on my other PC and a g code from fusion 360 using the centroid post processer
Spot drill.nc
(429 Bytes) Downloaded 35 times
Drill.nc
(421 Bytes) Downloaded 37 times
contour.nc
(1.94 KiB) Downloaded 36 times
clearing.nc
(49.69 KiB) Downloaded 35 times
report_E06234635550-0203225615_2022-05-22_11-43-30.zip
(618.24 KiB) Downloaded 39 times
Allin1Chris
Post by Allin1Chris »
Gansen,
Did you install the software off of a USB Drive by Chance? If so, ensure to copy the executable to your desktop or somewhere on your computer first, then run the installer.
Have you tried Running the CNC12 software in administrator mode ? (Right click the cnc12 icon on your desktop and click "Run as Administrator"). Does this resolve the issue ?
Centroid PLC Tutorial Videos
Gansen911
Post by Gansen911 »
I installed it right from the centroid page. I am running it as a administrator and seeing the same result.
avp
Post by avp »
Hello,
Has there been a solution to this issue? curious about it.
Thank you
Bill
Gansen911
Post by Gansen911 »
Unfortunately this problem is not fixed and still do not have answers.
